miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer [solved]
Dyn5
What is it and how can I get rid of it?
Here is the log file from today. I see this error message quite often.
Please Help. Thank you
May 9 09:22:10 dnsmasq-dhcp[444]: DHCPSOLICIT(br0) 00:01:00:01:1e:8b:72:56:9c:5c:8e:d1:ed:71
May 9 09:22:14 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.13 74:c6:3b:00:6d:2e
May 9 09:22:14 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.13 74:c6:3b:00:6d:2e X99
May 9 09:22:35 miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer
May 9 09:23:35 miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer
May 9 09:31:52 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.12 34:e6:ad:37:a0:9b
May 9 09:31:52 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.12 34:e6:ad:37:a0:9b ZBOX
May 9 09:31:53 dnsmasq-dhcp[444]: DHCPSOLICIT(br0) 00:01:00:01:1d:d7:a8:4a:00:01:2e:64:e3:8c
May 9 09:35:37 miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer
May 9 10:30:59 dnsmasq-dhcp[444]: DHCPSOLICIT(br0) 00:01:00:01:1d:d7:a8:4a:00:01:2e:64:e3:8c
May 9 10:31:04 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.12 34:e6:ad:37:a0:9b
May 9 10:31:04 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.12 34:e6:ad:37:a0:9b ZBOX
May 9 10:31:05 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.11 bc:8c:cd:df:a3:eb
May 9 10:31:05 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.11 bc:8c:cd:df:a3:eb TV
May 9 11:04:59 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.11 bc:8c:cd:df:a3:eb
May 9 11:04:59 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.11 bc:8c:cd:df:a3:eb TV
May 9 11:27:14 dnsmasq-dhcp[444]: DHCPSOLICIT(br0) 00:01:00:01:1e:8b:72:56:9c:5c:8e:d1:ed:71
May 9 11:27:16 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.13 74:c6:3b:00:6d:2e
May 9 11:27:16 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.13 74:c6:3b:00:6d:2e X99
May 9 11:28:48 miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer
May 9 11:59:44 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.13 74:c6:3b:00:6d:2e
May 9 11:59:44 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.13 74:c6:3b:00:6d:2e X99
May 9 11:59:46 dnsmasq-dhcp[444]: DHCPSOLICIT(br0) 00:01:00:01:1e:8b:72:56:9c:5c:8e:d1:ed:71
May 9 12:15:33 miniupnpd[822]: remove port mapping 41924 TCP because it has expired
May 9 12:15:33 miniupnpd[822]: remove port mapping 41924 UDP because it has expired
May 9 12:15:45 miniupnpd[822]: upnp_event_process_notify: connect(192.168.1.13:2869): No route to host
May 9 20:56:29 dnsmasq-dhcp[444]: DHCPSOLICIT(br0) 00:01:00:01:1e:8b:72:56:9c:5c:8e:d1:ed:71
May 9 20:56:34 dnsmasq-dhcp[444]: DHCPREQUEST(br0) 192.168.1.13 74:c6:3b:00:6d:2e
May 9 20:56:34 dnsmasq-dhcp[444]: DHCPACK(br0) 192.168.1.13 74:c6:3b:00:6d:2e X99
May 9 20:57:18 miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer
May 9 20:58:17 miniupnpd[822]: upnp_event_recv: recv(): Connection reset by peer
...Please Help. Thank you...
If you disable UPnP, you will never see again those warning messages
Thank you for your replies. I had some trouble with Homegroup lately and tried to find the error. If you say the miniupnpd log entry is just a normal entry, then I will ignore it ^^
I guess I should uninstall windows 10 from all my devices then ^^
I will try to figure out what the problem is.
How did you solve the trick? Just stick to Windows 7?
