Missing screens... in firmware screens
Vulnax
On both of these AC66U routers ( one RMA'd ) I had a problem seeing the graphs on traffic monitor. Just the tables visible, with a code? comments <endif>
Using Merlins latest firmware I get same isue on the performance tuning / temps page - no graphs, just an <endif> statement.
Also needs a few screen refreshed before even that comes up.
Any ideas? Settings to change? Something on the PC ? ( Win 7 64 bit 0.
V
[/IMG]
Open the error console to see if there is any Javascript error, and the line with the error.
Usually this happens if either you need to empty your browser cache, or you have a device on your network with an invalid name (containing quotes or other invalid non-alphanumerics in them).
I have exactly the same problems with the displays as you when I access the router via Internet Explorer 9 which, from your screen shots, it looks like you are using IE9. The displays show correctly with both the other browsers I use - Chrome, and Opera.
