Hello,
I recently bought a new router from Netgear, the WNDR3400, because my previous router was dying and my range within my home had deteriorated. Before I replaced it, I was using MoCA adapters to hardwire my desktop to my network (I've tried using a wireless card to resolve the issue but my computer will just crash repeatedly if I use it). Now that I've replaced my router, my MoCA adapters are no longer working.
From what I've seen, the modem that it is connected to doesn't receive any signal from the MoCA device. When the modem receives an internet connection, it reports cable activity by lighting up several different LED's. When I connect the MoCA device as it says to in the manual, the internet LED simply flashes, indicating that it is waiting on an internet connection. I've tested all the cables, and they all work, so I'm assuming its a problem with the internal splitters within the MoCA. I don't have a lot of experience with coaxial, so if there's any additional information needed, I'll be happy to offer what I can. I can say that (just from being in the room) the wall-coaxial cable has been split once already to provide service to a TV not more than 10 feet away, but I feel like that shouldn't matter since they worked before.
I've noticed that the MoCA does not send back out a MoCA traffic signal when I connect the other device to another coax connection, however, when I connected it to the coax connection that supports the TV that's across the room, both devices registered MoCA traffic. I don't feel like I should have to make any major changes to make this work. Any ideas?
