More than one DDNS
tiomiguel
ASUS DDNS is needed for the asus router APP, I believe
Tue question is If more than one DDNS service can be used at the same time
I Hve RT-AX82U with last firmware. I want to use free.afraid DDNS but If using it I do not know if ASUS DDNS discinects when using other DDNS
You only need one DDNS service. But, be careful with the Asus router app. If it asks to enable remote connection, do not enable it! It is a security risk. If you want to manage your router remotely, use a VPN. The Asus InstantGuard works well.
Yes it can; I have it set to "custom" and my custom script updates 2 DDNS addresses and generates a Let's Encrypt certificate for the second DDNS address as well.
Although I would recommend another service than ASUS DDNS
