Most reliable and lowest-impact network setup for Tivo Roamio + Mini + old Premier
ncfoster
This is a cross-post from what I just put in the Tivo Community, but I suspect that there may be good answers here as well:
I have a new Roamio Pro and Mini on the way. I am migrating from the basic Premiere, upgraded to 2TB.
I am looking to connect and configure things on my network in the most effective way, with an emphasis on reliability, of course, and nearly as important, not clogging up my main network.
My home network is configured with two wireless routers and a large gigabit switch distributing throughout the house. Specifically, I have an Asus RT-56U (running Padavan firmware) setup as the main router, with a D-LINK DGS-1016D gigabit switch feeding most of the wired connections in the house, and an Asus RT-N16 (running Tomato firmware) which sees minimal use, but gets somewhat better coverage with external antennas (all the hardware is in the basement). Finally, there is an Asus GX-D1081 gigabit switch with the main home theater.
Gigabit drops are available at all locations, and if desirable, I can use a straight dedicated run of coax from the Pro to the Mini without much trouble.
I understand that the Roamio Pro can behave as a MoCA bridge, and that the Mini can connect natively via MoCA as well.
My first question is whether that is the best way to go long-term with the Mini? Or am I better off sticking with the available ethernet?
My second question is how to connect the Premier, most likely short-term, to do the program transfer, with the least impact to my overall network performance? I don't think that MoCA is an option, unless I got a separate adapter.
Not being a network guru, the ideas that come to mind are segmenting the two routers, running separate subnets and/or VLANs, etc. I presume somebody has given more thought to things like this than I, and maybe tried multiple options.
Any help is greatly appreciated.
