multicast on ac56u
stevocz
i am changed router from n16 to ac56u. both has 43 firmware but on ac56u multicast not working. i am equally settings on both routers but on n16 it works and on ac56u no.
Have you try factory defaults/reset and nvram clean first?
after adding last firmware. but i can try again
now i am try reconfigure router but multicast is not working.
It doesn't work on the RT-AC66U, either. I think I've seen a few bugs mentioning Apple AirPlay before (uses multicast, doesn't work due to this defect) that were marked as WONTFIX for some reason. Multicast packets are not routing across two RT-AC66Us in media bridge configuration here. Flashing Tomato onto the one configured as a bridge makes it work, but significantly limits throughput as Tomato doesn't support the hardware acceleration supported by ASUSWRT.
It's pretty weird. Multicast will actually work for a very brief period immediately after changing what mode the router is in, but then it consistently stops working within a couple of minutes.
hi.
i am try older firmware and multicast on firmware 40 is working. but not working on newer firmware.
