Rana Imran
I’ve been running an AiMesh setup with two Asus RT-AX82U units (Firmware Version:3.0.0.4.388_25030), one as the main router and the other as an AiMesh node, plus an additional DSL-AC68U as another node. Everything had been working fine until yesterday.
Out of nowhere, my RT-AX82U node started disappearing from the AiMesh list. Instead of showing as a node, it suddenly appeared in the client list, almost like it had stopped being part of the mesh.
Today, I decided to do a full factory reset on the RT-AX82U node and re-add it to the AiMesh. The pairing worked perfectly at first, and the node showed up as expected. But after a short while, it happened again and the node dropped off and was back in the client list.
Has anyone else experienced this? What could be causing the RT-AX82U to keep removing itself from the AiMesh, and how can I fix it?
Edit: RT-AX82U Node is connected through cable.
