Aug 1 02:00:06 kernel: 0x01fe0000-0x02000000 : "nvram"
Aug 1 02:00:06 kernel: 0x017e0000-0x01fe0000 : "jffs2"
Aug 1 02:00:06 kernel: Found an serial flash with 0 0KB blocks; total size 0MB
Aug 1 02:00:06 kernel: sflash: found no supported devices
Aug 1 02:00:06 kernel: dev_nvram_init: _nvram_init
Aug 1 02:00:06 kernel: sdhci: Secure Digital Host Controller Interface driver
Aug 1 02:00:06 kernel: sdhci: Copyright(c) Pierre Ossman
Aug 1 02:00:06 kernel: u32 classifier
Aug 1 02:00:06 kernel: OLD policer on
Aug 1 02:00:06 stop_nat_rules: apply the redirect_rules!
Aug 1 02:00:06 kernel: Netfilter messages via NETLINK v0.30.
Aug 1 02:00:07 kernel: nf_conntrack version 0.5.0 (2048 buckets, 16384 max)
Aug 1 02:00:07 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Aug 1 02:00:07 kernel: net/ipv4/netfilter/tomato_ct.c [May 10 2016 11:45:15]
Aug 1 02:00:07 kernel: ipt_account 0.1.21 : Piotr Gasidlo <
[email protected]>,
http://code.google.com/p/ipt-account/
Aug 1 02:00:07 kernel: NET: Registered protocol family 1
Aug 1 02:00:07 kernel: NET: Registered protocol family 10
Aug 1 02:00:07 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Aug 1 02:00:07 kernel: NET: Registered protocol family 17
Aug 1 02:00:07 kernel: 802.1Q VLAN Support v1.8 Ben Greear <
[email protected]>
Aug 1 02:00:07 kernel: All bugs added by David S. Miller <
[email protected]>
Aug 1 02:00:07 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Aug 1 02:00:07 kernel: Freeing unused kernel memory: 196k freed
Aug 1 02:00:07 kernel: Warning: unable to open an initial console.
Aug 1 02:00:07 kernel: Algorithmics/MIPS FPU Emulator v1.5
Aug 1 02:00:07 kernel: ctf: module license 'Proprietary' taints kernel.
Aug 1 02:00:07 WAN Connection: ISP's DHCP did not function properly.
Aug 1 02:00:07 kernel: et_module_init: passivemode set to 0x0
Aug 1 02:00:07 kernel: et_module_init: et_txq_thresh set to 0xce4
Aug 1 02:00:07 kernel: bcm_robo_enable_switch: EEE is disabled
Aug 1 02:00:07 kernel: eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 6.30.163.2002 (r382208)
Aug 1 02:00:07 kernel: wl_module_init: passivemode set to 0x0
Aug 1 02:00:07 kernel: PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
Aug 1 02:00:07 dropbear[230]: Running in background
Aug 1 02:00:07 kernel: eth1: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Aug 1 02:00:07 kernel: PCI: Enabling device 0000:02:01.0 (0000 -> 0002)
Aug 1 02:00:07 kernel: eth2: Broadcom BCM4331 802.11 Wireless Controller 6.30.163.2002 (r382208)
Aug 1 02:00:07 kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Aug 1 02:00:07 kernel: br0: starting userspace STP failed, staring kernel STP
Aug 1 02:00:07 kernel: vlan1: dev_set_allmulti(master, 1)
Aug 1 02:00:07 kernel: vlan1: dev_set_promiscuity(master, 1)
Aug 1 02:00:07 kernel: device eth0 entered promiscuous mode
Aug 1 02:00:07 kernel: device vlan1 entered promiscuous mode
Aug 1 02:00:07 kernel: device eth1 entered promiscuous mode
Aug 1 02:00:07 kernel: device eth2 entered promiscuous mode
Aug 1 02:00:07 kernel: br0: port 3(eth2) entering listening state
Aug 1 02:00:07 kernel: br0: port 2(eth1) entering listening state
Aug 1 02:00:07 kernel: br0: port 1(vlan1) entering listening state
Aug 1 02:00:07 kernel: br0: port 3(eth2) entering learning state
Aug 1 02:00:07 kernel: br0: port 2(eth1) entering learning state
