Hi all,
Apologies for bringing up a topic that I can see is fairly old but I just cannot seem to get things working and Ive done a lot of searching.... (running 386.2)
My understanding (for anybody else in the future who searches) is that EZIPUPDATE didn't previously support https (which namecheap required), hence a custom JFFS script was advised (a la this post), however more recently https is supported so this is no longer a requirement for the IP update part (unknown about Let'sEncrypt certificate).
I have a namecheap domain blahblah.net and a dynamic A record for the whole domain (@), rather than using sub domains. I can successfully update this record either using the script mentioned above, or the built in namecheap.com DDNS 'tool', however in no circumstances can I get a LetsEncrypt certificate to generate:
Can somebody help point me in the right direction please?
Thanks very much!
- Using the built in tool (with an @ as the hostname) it will update, but tells me the @ character is invalid for LetsEncrypt - in which case is it not possible to have a blahblah.net certificate and I *HAVE* to use a subdomain?
 - Using the script I have tried changing the hostname in the script between @/*/blahblah.net and I have tried changing the hostname in the web interface between these same options. With several of these I can successfully update my DDNS record, but I can't seem to trigger the LetsEncrypt tool to attempt getting a certificate. Occasionally I will see it in the logs, but has clearly never succeeded as its always stuck in the 'Authorizing' state....
Thanks very much!
