NAT loopback on v380.57 and RT-AC68U
Ian Manning
I've been trying to get NAT loopback working on my RT-AC68U, but have had no luck. I've tried:
- Both Merlin and Asus NAT Loopback
- Disabling NAT acceleration
- Disabling/enabling the firewall
- Disabling/enabling port forwarding.
I did a factory reset and two power cycles when flashing Merlin (as advised elsewhere on this forum), but I still can't access LAN resources (IP cams, web servers, etc) using external IP addresses.
Has anyone got NAT Loopback working on the RT-AC68U with Merlin v380.57?
If you have NAT acceleration disable, your 2.4ghz band is probly broken.Try reaching internet with a wireless device if NAT is disabled, you surely cant.
Its a knowed problem with 380.57 and 380.1031 asus for the Ac68
You're right - I hadn't noticed that the 2.4Ghz band was broken. So is there any way of getting NAT Loopback working with Merlin at the moment?
