need a dump of partitions - rt-ax89x
CrashXRu
need a dump of several partitions
due to the strong difference from the BCM platform, a dump is needed to verify the correct movement
ideally
Canada, USA, Australia, China
European copy already available
to do this, run a few commands copy the files and upload to any file hosting
cat /dev/mtd1 >mtd1.bak
cat /dev/mtd3 >mtd3.bak
cat /dev/mtd4 >mtd4.bak
files will be located in the root folder
