Hi Folks,
I would appreciate some guidance on planning/optimizing my network layout. I am not very well versed with network planning or network infra but have played around with different tech over a period of time.
The first pic is my current network layout. A couple of points:
* 2 separate Fiber Broadband (1 Gbps) connections from 2 different ISPs.
* 2 different LAN networks. One for laptops, phones and the other for smart devices, Sonos, smart things, firetv, PlayStation, Tp-link smart bulbs, smart plugs etc.
* One network is Orbi Mesh (laptop, phones). The other one is Netgear router flashed with DD-WRT running Astrill VPN. Some devices tunnel through the VPN.
* Have an extender as some smart devices are on different floors. This is connected to the Netgear router.
* Running Cat 5/6 cables was not an option and looking for wireless solutions. Most of the client devices are on wireless as well.
* Pi-Hole DNS is connected to one of the networks. In the past, this network was also behind a Cujo firewall. This is mostly an experiment to test if some devices are too chatty
With the new network (second image), I hope to:
* Have a load balanced, multi-wan solution that combines both my internet connections. [Considering a Qotom device with Pfsense]
* Have a switch connected to Qotom. Doing this to segregate traffic into multiple VLANs to separate traffic. Not sure if this is possible or even the best approach.
* My understanding is it’s not possible to have VLANs for wifi, so planning to have the old router as an access point to connect the remaining smart devices.
* Netgear Orbi becomes an access point as well for the other laptops and phones.
I have a couple of questions:
* Does this design make sense? I am assuming that are better ways to achieve these outcomes than the franken-network that I have
* Are there better options to multi-wan, firewall than qotom/netgate to combine multiple internet connections for gigabit load balanced scenario?
* I am assuming that the switch in the center would be able to create VLAN and separate traffic for different scenarios (Sonos, Smartthings, Firetv, PlayStation, etc). If so, what kind of a switch I should consider?
* My current router (dd-wrt flashed) for smart devices has Astrill VPN for Netflix that some devices tunnel through. Would this be overkill in the new setup or pfsense itself will suffice with OpenVPN?
Happy to hear from folks and would appreciate any guidance and feedback that you might have for me.
Best,
Rajat
Best,
Rajat
