Need help setting up a VPN server
Is there any guides to setup vpn to access the router when i'm away from home? Thanks.
Sure, you will probably want to look at Wireguard (WG) as it is pretty quick.
OpenVPN is older, slower but reliable.
Below are ASUS How to's on this to startoff with.
Then install the WG App for your iOS or Android or Windows device.
See how you get on, come back and ask questions when you get stuck :-)
Wireguard
OpenVPN
