Need help with iptables
FalconB
Scratching my head trying to configure iptables and need some advise.
Setup:
  • RT-AC68U
  • Router IP: 192.168.1.1
  • Running DNScrypt on router, hence all devices point to router IP (192.168.1.1) for DNS
  • Router running OVPN server with IP range: 192.168.10.0/24, ie OVPN client 1 gets IP address 192.168.10.2
Everything is working as it should. I can connect through the VPN and surf the web as if I were surfing from within my LAN, without DNS leaking. Yay!
However, I want to restrict the OVPN-clients from reaching any LAN-devices. But, since I use DNScrypt, they still need to access the DNS-server, ie my router, on port 53 (right?).
From my understanding this can be done through the OVPN server settings in combination with iptables, but I'm a novice in that area and need help configuring it.
Any help appreciated!
