Need to reconnect to GUI RT-AC68W after factory reset
pdoyle
Please advise; I've done a reflashing of latest firmware to RT-AC68W, then entering manual settings after factory reset. Now after rebooting the router, I cannot access it at 192.168.1.1; I cannot determine the 'updated IP address and port number' to reconnect to. I have the internet and can connect to the ethernet, and wifi network; but cannot pull up the GUI screen. Device discovery only shows the router at 192.168.1.1. I'm missing something that I've been able to do many times before. Ipconfig/release, renew; restarts; nothing is working. Thanks in advance.
gives the same result
thanks! different browser, same result. Problem solved; was only able to connect to router by using Asus router app on cellphone, and rebooting through the GUI a few times. Now my pc can access router GUI. Rebooting by removing power was not working...
Now I'll re-flash firmware to to the RT-N66R in Access Point mode on the network; but this time I'll enter new settings manually after a factory reset of that RT-N66R Access Point. Just to be thorough. Thanks to L&LD flashing firmware guide at snbforums.com/threads/noob-definition-of-minimal-and-manual-configuration.27115/
