Needing network setup/device help (I am a NOOB)
clints12
I am attempting to setup a network for internet and local access of computers, below is the available components and design idea.
Netgear 781S LTE Router/Hotspot --> Amped Wireless R1000 (Router, using as access point (at least that is what I understand I should be using it as)) --> Computers and tablets
I want to get the internet access from the 781S and use the R1000 as the connection point for all devices. My research has found that another component is needed between the 781S and the R1000. What would be the best and most cost efficient way to achieve this?
Your probably thinking about a switch, which is not necessary unless you are simply connecting the amped AP to the router.
