Netdata portforwarding on AC68U
ipkpjersi
Hi everyone,
I installed netdata (opkg install netdata) on my AC68U with Merlin 384.12 firmware and it has been working great - no noticeable issues in regards to the RAM or CPU utilitzation. However, I can't seem to port forward netdata on my router itself. I forwarded port 19999 for my desktop for netdata just fine, however, port forwarding 20000 (to point to internal port 19999) for my router is not working - even with the firewall off, I cannot access my router's netdata but I can access my desktop's netdata remotely with my LTE phone connection. I'm not exactly new to port forwarding but I might be missing something here. Does anyone have any ideas?
I apologize if this is not the right section, but as I'm using Merlin firmware I'm not sure if this is somehow a bug or if I'm doing something wrong.
Thanks.
Hi everyone,
Thanks.
You can't forward a port to the same device - you have to add a rule to the INPUT chain instead
Awesome, that worked perfectly. I decided to leave netdata on the router as port 19999 and then did:
iptables -I INPUT -p tcp --dport 19999 -j ACCEPT
After that, I created a /jffs/scripts/firewall-start script:
#!/bin/sh
I then set the firewall-script to have execute permissions:
chmod +x /jffs/scripts/firewall-start
It's also worth setting netdata as a service, by creating file /jffs/scripts/services-start:
nano /jffs/scripts/services-start
#!/bin/sh
sleep 60
/opt/etc/init.d/S60netdata start
I then set the services-start file to have execute permissions:
chmod +x /jffs/scripts/services-start
I then changed netdata.conf to allow all IPs to access it:
nano /tmp/mnt/AC68U/entware/etc/netdata/netdata.conf
[web]
allow connections from = * localhost 10.* 192.168.* 172.16.* 172.17.* 172.18.*
allow dashboard from = * localhost 10.* 192.168.* 172.16.* 172.17.* 172.18.* 1
After that, I could access netdata remotely. I will likely secure it now that I have tested that it works remotely. Thanks! I hope this post can now be helpful to someone who comes across it.
