Netgear Genie
Gapmn
Has anyone bean able to use Netgear Genie to login to two different WAP's (one at a time) on the same network? I can only access one of the AP's.
Which device you are trying this
As such if you need to cont to devices at the same time then you either needs to have dual lan or Dual wireless adapters or lan and wireless
I don't need to access them simultaneously. I just want to have the ability to access them one at a time using the Netgear Genie. Like I said, I can only access one of them for some reason.
And you can access each R8000 via its web admin interface?
No, I can only access one of them for some reason. That's what I'm trying to find out. How do I access both of them?
I thought you were using the Genie app.
You should ping each IP to be sure it is there.
I am using the Genie app. If I select signin by IP, I can only sign into one R8000 using an iPad. However, I can sign into both R8000's on a PC loaded with the Genie.
