D-Link DGS-1210-28P (F3) -- Cannot access WebGUI after factory reset.
snively
Hi all,
Pulled this out of the garage today, where it has sat since I took it from a customer's site (they upgraded). I have some IP cameras sitting around I wanted to mess around with so I've been trying to get this damn thing operational. I followed the instructions via the manual (and what others have mentioned online). I can ping 10.90.90.90 but I cannot access the WebGUI in Chrome, Firefox, Brave, Edge, or Internet Explorer mode in Edge. I also am not able to telnet into it. I was able to find a copy D-Link's Network Assistant on one of their foreign/European websites and gave that a go. DNA is able to see the switch online, but I can't do anything with it. In the "Auth" column, the icon says Locked. I can click it to go in and enter the login/password (admin/admin) but it says incorrect username/password. It kind of feels like the factory reset didn't take, but I have reset it 10+ times so I'm not sure what's going on.
Has anyone else come across this issue with one of these D-Link switches and figured out a solution?
Here's a vid showing what I'm talking about: https://streamable.com/xptatv
Dlink default admin ip should be 192.168.0.1 default password could be admin or blank.
According to the manual, when connecting to the default IP (screenshot: 10.90.90.90), you only need to enter the password "admin". However, I am unable to access the WebGUI. Elsewhere in the manual when looking at the CLI section it says both username/pass are "admin" but when entering that info in DLinks Network Assistant utility it gives me an error like in the video I linked in my first comment.
The switch isn't connected to any part of my network, it's just the DLink and my laptop. Someone elsewhere mentioned it likely has a bad web / management interface if I can't access it via a browser or telnet
Just to clarify. The router came with asus 3.0.0.4 firmware, you set it up, then you flashed Merlin's 3006 firmware?
3.0.0.6, and hence 3006 firmware now has newer restrictions on passwords. If you change your login password in the router's gui then you should be able to use the new password for ssh.
Normally I'd recommend a reset after moving from Asus to Merlin - you may still have to do just that.
He's talking about a D-Link switch not an Asus router.
