I recently came accross a discount on Amazon on netgear stuff and thought it would be a good thing to upgrade my R7000 to R7800.
Now I have both routers set up, but the R7800 provides a weaker s5G signal than the R7000.
At my desktop spot, I get around 150Mbps with the R7000 vs 80/90 with the R7800.
Also, I noticed the upload speed is 2 times more than the download speed. Around 200Mbps upload on R7800.
The gain attenuation is like -70/75 with the R7800 vs around -65 with the R7000.
What I have tried on the R7800 :
-change the antenna orientation
-test multiplme firmware, stock and custom
-resetted the router after each firmware upgrade
Thing I was not able to try :
-disable mu-mimo because I get an error when clicking on "apply" settings, impossible to apply ...
I am a bit lost and desperate. I would like to get this R7800 to work, but it just seem it does not want.
Any advice ?
Any advice ?
