Network down firewall not working fine?
Miguel
It drops the network, when receiving DRDOS (CHARGEN) attack, I have a router asus rt-ac66u B1, with its last alpha firmware but when I launch a ddos attack it falls the entire internal and external network, some way to solve it? Formerly used another router and did not drop the network, only worked slower.
I have added a script (/jffs/scripts/ firewall-start:) with
#!/bin/sh
iptables -A INPUT -p udp -m limit --limit 5/s  -j RETURN
iptables -A INPUT -p udp -m limit --limit 5/s  -j LOG
iptables -A INPUT -p udp -m udp --sport 19 -j DROP
If the attack lasts 5 minutes, the wan and lan fall
I feel my english bad.
Are you doing this from the LAN side or the WAN side?
WAN side - one should be safe as long as the Character Generator port (UDP/19) isn't exposed - which typically it is not.
[Quote = "sfx2000, mensaje: 315.694, miembro de: 7568"] ¿Estás haciendo esto desde el lado de la LAN o la WAN?
lado WAN - uno debe ser seguro, siempre y cuando el puerto generador de caracteres (UDP / 19) no está expuesto -. que típicamente no es [/ QUOTE]
Yo uso esta web:
https://www.ipstresser.com
