New 87U log entries.
  • Thread starter Thread starter Deleted member 22229
  • Start date Start date
D
Guest
New RT-AC87U just got this up and running and noticed the 5 ghz led blinks instead of being steady any reason for this. Also looks like the 5 Ghz radio is running hot (2.4 GHz: disabled - 5 GHz: 64°C - CPU: 76°C) any thoughts?
Wanted to add do these numbers seem right 5 ghz band channel 44.
RSSI: 0 dBm SNR: 32 dB noise: -43 dBm Channel: 44/80
Also found these is the syslog tonight any thing to be concerned about ? Sorry for all the questions this router is completely new to me.
Jan 30 17:18:35 kernel: * Make sure sizeof(struct sw_struct)=160 is consistent
Jan 30 17:18:35 kernel: IDPfw: TrendMicro forward module ver-1.0.25
Jan 30 17:18:35 kernel: IDPfw: Apply module param dev_wan=vlan2
Jan 30 17:18:35 kernel: IDPfw: Apply module param sess_num=30000
Jan 30 17:18:35 kernel: IDPfw: Init chrdev /dev/idpfw with major 191
Jan 30 17:18:35 kernel: IDPfw: IDPfw is ready
Jan 30 17:18:35 kernel: sizeof forward param = 160
Jan 30 17:18:49 kernel: IDPfw: Exit IDPfw
Jan 30 17:18:49 kernel: Stop the IPS/AppID engine...
Jan 30 17:18:49 kernel: mod epilog takes 0 jiffies
Jan 30 17:18:49 kernel: IDPfw: Exit chrdev /dev/idpfw with major 191
Those are normal notices from the DPI engine.
G Traffic monitor log incomplete ASUS AC Routers & Adapters (Wi-Fi 5) 3
