So if RMerlin's build was updated to include the changes in this build would I see the signal increase and stable speed that you indicatedInstalled this firmware and so far so good in AP mode. Signal increased on both bands. Speed seems to be stable on all devices especially iPad, iPhone, Macbook. Haven't test AC mode yet with the PCE-AC66...
I wish there was a way to ignore you
I tried this version, and unfortunately, like the previous version 376.1123, my laptop does not connect at a speed higher than 300 Mpbs. When I use firmware 374.5517 I can connect at 867Mbps, which is the maximum speed with Intel AC7260 client. Does anyone else have the same problem with this firmware?
Thanks in advance.
Make sure mode is set to Auto. The N+AC setting is broken and doesn't work properly in recent versions - Auto will handle both N and AC.
Thanks-- I'm aware. I saw it yesterday soon after it was released. I installed it and 3602 resolves the issue I had with 2524.
We use essential cookies to make this site work, and optional cookies to enhance your experience.
