New! Black Sev7en Media Center Edition Theme Build 815
tipstir
http://www.mediafire.com/imgbnc.php/...3fc52b185g.jpg
Introducing Black Sev7en Media Center Edition Theme for Media MVP.
I was inspired to create this theme after the current release of Windows 7.
The selector method would be the very first item on top of the list in this example above Movie Library would be selected.
Under Picture Library you can go to either direction shown with the selection choice you have.
This has all the latest patch fixes and now the Web browser can be use
to view real HTML pages instead of using JPEG image screen dumps. To
exit out of the Web Browser you need to press 2x Back/Exit.
Download Build 815 - 10/23/09 (USA Link)
http://www.mediafire.com/download.php?iywnmtmcmzr
Note: Media MVP Customizer Build 215 or higher will support this newer theme only.
