Tim
In your performance review test you identified one of the CONS to be "Fast USB 3.0 backup only to EXT3 format". Later in your review you discussed backup tests runs and your comments were as follows:
What you don't see in the Benchmark Summary are the results of my backup tests using a WD MyBook 3.0 USB 3.0 drive, which testing using Vista SP1 file copy showed capable of 82 MB/s write and 117 MB/s read. But, once again, using NTFS format yielded only 14 MB/s and FAT was fastest at 67 MB/s (EXT3 was a disappointing 23 MB/s). Although 67 MB/s is a hell of a lot better than previous USB 2.0-only ReadyNAS backup options, it pales in comparison with 80+ MB/s speeds that QNAP eSATA backup provide.
I think you meant to say Fast USB3 Backup only to FAT32 format?
Also, note that Netgear specifies the Pro2 as the only Pro NAS that does not come with Enterprise class disks. Yours did, which begs the question - Do they ship some units with Enterprise disks or, is their spec sheet wrong? I'd hate to think they sent you a special version.
I'll check into that with my pals @ Netgear.
http://www.readynas.com/wp-content/uploads/2009/03/ReadyNAS_Comparison_Business.pdf
