NextDNS CLI with Guestnetwork Pro
K3r1m0
I have installed NextDNS CLI on my router and all my devices are displayed in nextdns dashboard. I want my devices on Guest Network with a separate subnet to also connect to NextDNS CLI so those devices are displayed. I can't get it to work even though I have given access to intranet. The only way I have succeeded is to enter NextDNS IP addresses as DNS servers for the guest network, but then the device name is not displayed, only the IP address of the router.
I am using Guest Network PRO on 3006.102.5
Anyone know if it works?
For my own experience there is no easy way for this unless you use iptable rules to redirect all guest networks to where nextdns cli does the capture, 127.0.0.1:53. One solution that i use for my vpns it so use a different profile so its easier to identify what devices is quering what without it being identified by nextdns, but if you have ton of devices on the guest network it could be next to doing nothing.
In an untested theory, you could add the same commands to dnsmasq-sdn.postconf as in dnsmasq.postconf and see if it works.
#!/bin/sh
# Configuration generated by NextDNS
CONFIG="$1"
. /usr/sbin/helper.sh
if [ -f /tmp/nextdns.pid ] && [ -d "/proc/$(sed -n '1p' /tmp/nextdns.pid)" ]; then
    pc_append "no-resolv" "$CONFIG"
    pc_delete "servers-file" "$CONFIG"           # disconnect dnsmasq from WAN DNS settings
    pc_delete "resolv-file" "$CONFIG"            # disconnect dnsmasq from WAN DNS settings
    pc_append "server=127.0.0.1#5342" "$CONFIG"  # point dnsmasq to NextDNS listener IP:port
    pc_delete "stop-dns-rebind" "$CONFIG"        # disable DNS rebind if enabled
    pc_delete "trust-anchor=" "$CONFIG"          # disable DNSSEC
    pc_delete "dnssec" "$CONFIG"                 # disable DNSSEC
    pc_append "add-mac" "$CONFIG"
    pc_append "add-subnet=32,128" "$CONFIG"
fi
## NextDNS END
