NFS issue[ac86u]
ziolupo
Dear Merlin,
I just bought a brand new AC86U router. I will use the old 68U as access point).
Both routers are using version 384.6 of your great firmware
With Ac68U there is the following switch in NFS panel:
with the new AC86U, the legacy option is missing:
Without that option, my 3 Raspberrys with OpenElec are not able to discover the NFS server.
I reisnstalled the AC68U and I did some test: with the switch on is working, without is not working.
Funny because on OpenElec NFS is version 4.1... not really a legacy version!
Is it possible to have that switch back?
Thank you!
ZioLupo
Asuswrt-Merlin does not support 4.1, so you must be falling back to v2 when it fails to connect. Disabling legacy only enables v3.
The problem is that the switch For enabling legacy is not present in ac86u.
Only possible with ac68u as you can see from my previous pictures.
That's because NFS v2 is no longer supported by the kernel used by the RT-AC86U, so that model only supports V3.
