Unbound No GUI stats
BeachGuy
I know this has been mentioned before but the suggestions didn't seem to help. When I install GUI there are no stats and the left side menu is black (nothing). Merlin v3006.102.4. Config includes:
# integration LOG's
verbosity: 5 # v1.02 '1' is adequate to prove unbound is processing domains
logfile: "/opt/var/lib/unbound/unbound.log" # v1.01 as per @dave14305 minimal config (v3.06 now deletes this if size grows > 10MB)
log-time-ascii: yes # v1.01 as per @dave14305 minimal config
log-tag-queryreply: yes # v1.02 @Martineau Explicitly Tag log-queries/replies with 'query'/'reply'
log-queries: yes
log-replies: yes
use-syslog: yes # v1.02 @Martineau Recommended to let scribe/syslog-ng handle the log(s)
log-local-actions: yes # v1.02 @Martineau ('yes' required for @juched's Graphical Ad Block statistics)
log-servfail: yes # v1.01 as per @dave14305 minimal config
/tmp/home/root# unbound-checkconf
unbound-checkconf: no errors in /opt/var/lib/unbound/unbound.conf
What is "develop version of the WebUI"?
No I didn't know that's where to post it as 3006.102.4 is release version, not beta. However, I think I figured it out. There's a setting under advanced for stats-gui. But it only shows % cache over last day, 5 days, 30 days or something like that. Not very detailed.
Regardless of if you have 3006 beta F/W or the stable F/W version installed, the develop version of the Unbound GUI should be installed for it to function correctly.
The production version only works with 3004 F/W
Ok gotcha, I missed that. So release versions aren't fully tested? There are still "development" issues after release?
The issue is with your unbound Add-on. Which is why I told you to update it to the develop version here:
And provided a link to instructions on how to do that.
Ok thanks for pointing that out. I will install and test this weekend.
No difference. In fact no stats at all. Previous it was showing % cache hit, now "no data to display".
No idea what your talking about unfortunately, works fine for me and many others. You'd have to provide much more detail as to what you did, or trying to do. We can't be guessing, just saying it doesn't work isn't enough when it works for others.
Installed via your link. Enabled gui from amtm:unbound. Enabled scribe. Stats point to my router IP (
s = Show unbound Extended statistics (s=Summary Totals; sa=All; http://10.10.50.1:80/user2.asp). No stats at all. Previous it was showing % cache hit, now "no data to display". I uninstalled gui rebooted, reinstalled gui rebooted.
Sounds like you ran my link and then enabled the WebUI? Which would be the wrong order since enabling it afterwords would risk it being replaced.
You should enable it, confirm it's broken (which it sounds like it is already) and then and then download it with the link, and then reboot.
Reinstalled from your link and rebooted and no "addons" tab. That's why I ran "add gui" before.
That's fine, it's what your supposed to do and what I asked you to do. To enable the GUI first, then download via my link, and then reboot. What are you doing now?
I'm saying your primary instructions did not say that at all:
If you downloaded via my link first, and then enabled the GUI from unbound, in that order, that would likely not work.
At this point I'd say uninstall anything related to unbound. Reinstall by doing a basic setup of unbound. Enable the WebUI. Run the link, reboot.
Once it works then you can tweak your settings as needed. Also provide screenshots of the steps your taking.
