sandiegoboy
Looking for some sugestions
I have a 3 story home with cable internet and AX86U as main router (2Floor), AX58U (1st floor) as first node and AC68U (basement) as second nore. The setup is as follows
However, I just signed up for fiber internet. I am waiting for it to be installed but I was thinking I have to rethink the whole thing again. I am not sure how the install goes but I assume they will leave the fibre terminal on the utility room on the basement.
Before, I was able to leverage the cable wire to bring the cable modem to second floor without using an eth wire. So I have the AX86U on 2nd floor right next to the coax /cable modem and also next to eth outlet (going down to the basement where it would go to the rest of the home)
I am thinking my options. I still want wired backhaul
- My house has wired ethernet from the basement utility room to 2 ETH ports in the basemenet, 2 ETH ports on the1 floor and 2 ETH ports on the 2 Floor. Ports are distant (not on same jack). All these ports are connected via an ethernet switch
- Cable modem is located on 2 Floor and conexted to AX86U, wired eth to basement through switch and then through wire to AX58U and AC68U
- Most clients are on second floor and first floor. Seldom anybody goes to the basement
- I can get yet another asus / 3rd party router (maybe disable wifi) and put it in the utility room as main node and connect to the other nodes? Cost + performance implications?
- Find a way to add eth wire in the basement so have a ethernet outlet with two ports, move AX86U here and connect WAN from fibre terminal and return LAN to distribute to other points via switch ? Some hustle wiring, avoid performance hit but put main router in an area with not people
