I am running an Asus RT-AC66R and have two Asus gigabit switches between my machine and the router, two cables are Cat 6 and one is Cat 5e (the Cat 5e was installed when the house was built).
I notice that sometimes my ping is a little higher than other machines on the network, but im wondering what is normal. Here is my results from pinging the router.
C:\Windows\system32>ping 192.168.1.1
Pinging 192.168.1.1 with 32 bytes of data:
Reply from 192.168.1.1: bytes=32 time=9ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=4ms TTL=64
Thanks for any input you guys may have
