Not able to compile latest Github pull for AX88U and AC86U
Blacklistedcard
I'm trying to compile the latest pull from GitHub and build for ac86u and ax88u, but both fail. Anybody able to build successfully from a latest pull?
Master is currently not in a buildable state. You need to remove desdata.stamp from router/nettle, and cherry-pick ac0e2c41395c97add6fb4d2af7939dfd0a33920. There might be other issues, I haven't looked into them yet.
Since the repo is now hobbled by missing proprietary Trend Micro components, how are you finding the resulting builds? Or is this your first build?
Here is the error during compile from the latest pull.
configure.ac:339: warning: gl_FUNC_SETLOCALE_NULL is m4_require'd but not m4_defun'd
m4/nl_langinfo.m4:7: gl_FUNC_NL_LANGINFO is expanded from...
m4/gnulib-comp.m4:398: gl_INIT is expanded from...
configure.ac:339: the top level
configure.ac:129: error: possibly undefined macro: gl_WARN_ADD
If this token and others are legitimate, please use m4_pattern_allow.
See the Autoconf documentation.
configure:12490: error: possibly undefined macro: gl_ZZGNULIB
configure:17584: error: possibly undefined macro: gl_FUNC_SETLOCALE_NULL
configure:27224: error: possibly undefined macro: gl_FUNC_ACCESS
configure:27684: error: possibly undefined macro: gl_FUNC_CANONICALIZE_FILENAME_MODE
configure:27727: error: possibly undefined macro: gl_FUNC_CHDIR_LONG
configure:27739: error: possibly undefined macro: gl_PREREQ_CHDIR_LONG
configure:27898: error: possibly undefined macro: gl_FUNC_CLOSEDIR
configure:27911: error: possibly undefined macro: gl_DIRENT_MODULE_INDICATOR
configure:28439: error: possibly undefined macro: gl_CTYPE_H
configure:28440: error: possibly undefined macro: gl_CHECK_TYPE_STRUCT_DIRENT_D_INO
configure:28441: error: possibly undefined macro: gl_DIRENT_H
configure:28442: error: possibly undefined macro: gl_FUNC_DIRFD
configure:28455: error: possibly undefined macro: gl_PREREQ_DIRFD
configure:28504: error: possibly undefined macro: gl_FUNC_DUP
configure:28516: error: possibly undefined macro: gl_PREREQ_DUP
configure:28762: error: possibly undefined macro: gl_FUNC_FCHDIR
configure:29086: error: possibly undefined macro: gl_FUNC_FDOPENDIR
configure:29247: error: possibly undefined macro: gl_FILE_NAME_CONCAT_LGPL
configure:29248: error: possibly undefined macro: gl_FINDPROG_IN
configure:30142: error: possibly undefined macro: gl_FUNC_FREE
configure:30154: error: possibly undefined macro: gl_PREREQ_FREE
configure:30474: error: possibly undefined macro: gl_FUNC_FSTATAT
configure:31318: error: possibly undefined macro: gl_FUNC_GETCWD
configure:31330: error: possibly undefined macro: gl_PREREQ_GETCWD
configure:31354: error: possibly undefined macro: gl_FUNC_GETCWD_LGPL
configure:32475: error: possibly undefined macro: gl_FUNC_GETRANDOM
configure:32488: error: possibly undefined macro: gl_SYS_RANDOM_MODULE_INDICATOR
configure:33482: error: possibly undefined macro: gl_FUNC_ISBLANK
configure:33502: error: possibly undefined macro: gl_CTYPE_MODULE_INDICATOR
configure:33569: error: possibly undefined macro: gl_FUNC_ISWDIGIT
configure:33601: error: possibly undefined macro: gl_FUNC_ISWXDIGIT
configure:36493: error: possibly undefined macro: gl_FUNC_MEMPCPY
configure:36505: error: possibly undefined macro: gl_PREREQ_MEMPCPY
configure:37717: error: possibly undefined macro: gl_OPEN_TRAILING_SLASH_BUG
configure:37759: error: possibly undefined macro: gl_FUNC_OPENAT
configure:37771: error: possibly undefined macro: gl_PREREQ_OPENAT
configure:37794: error: possibly undefined macro: gl_FUNC_OPENDIR
configure:37949: error: possibly undefined macro: gl_FUNC_POSIX_SPAWN_FILE_ACTIONS_ADDCHDIR
configure:38605: error: possibly undefined macro: gl_FUNC_READDIR
configure:38619: error: possibly undefined macro: gl_FUNC_READLINK
configure:38631: error: possibly undefined macro: gl_PREREQ_READLINK
configure:38648: error: possibly undefined macro: gl_FUNC_REALLOC_POSIX
configure:39119: error: possibly undefined macro: gl_FUNC_REWINDDIR
configure:39133: error: possibly undefined macro: gl_SAVE_CWD
configure:39686: error: possibly undefined macro: gl_PREREQ_SETLOCALE_LOCK
configure:41363: error: possibly undefined macro: gl_FUNC_STPCPY
configure:41375: error: possibly undefined macro: gl_PREREQ_STPCPY
configure:42601: error: possibly undefined macro: gl_HEADER_SYS_RANDOM
configure:45673: error: possibly undefined macro: gl_FUNC_WMEMCHR
configure:45701: error: possibly undefined macro: gl_FUNC_WMEMPCPY
make[7]: *** [Makefile:1690: configure] Error 1
make[7]: *** Waiting for unfinished jobs....
configure.ac:339: warning: gl_ZZGNULIB is m4_require'd but not m4_defun'd
m4/gnulib-common.m4:11: gl_COMMON is expanded from...
configure.ac:51: error: required file 'build-aux/compile' not found
configure.ac:51: 'automake --add-missing' can install 'compile'
make[7]: *** [Makefile:1664: Makefile.in] Error 1
make[7]: Leaving directory '/home/admin/amng.ax88/release/src/router/wget'
make[6]: *** [Makefile:7185: wget] Error 2
make[6]: Leaving directory '/home/admin/amng.ax88/release/src/router'
make[5]: *** [Makefile:30: router_all] Error 2
make[5]: Leaving directory '/home/admin/amng.ax88/release/src-rt-5.02axhnd/userspace'
make[4]: *** [make.hndrt:329: userspace] Error 2
make[4]: Leaving directory '/home/admin/amng.ax88/release/src-rt-5.02axhnd'
make[3]: *** [make.hndrt:115: parallel_targets] Error 2
make[3]: Leaving directory '/home/admin/amng.ax88/release/src-rt-5.02axhnd'
make[2]: *** [Makefile:609: all] Error 2
make[2]: Leaving directory '/home/admin/amng.ax88/release/src-rt-5.02axhnd'
Yes, and I already posted the solution in my previous message.
