Occasional no response from DNS server when Dual WAN is on
02m
I am in the middle of switching my ISP and figured that this is a perfect time to try out the Dual WAN feature. Everything is running smoothly, but I have noticed that occasionally after typing in a website address I instantly get an error in the browser. But after refresh everything is fine again.
I have tried to reproduce it by constantly sending DNS queries to the router by:
watch -e -n 1 "drill test.2m.lt @192.168.1.1 | grep -m 1 SOA"
and I see that is takes less than a minute for watch command to stop, which means that no response has been received from the router DNS server.
When I turn Dual WAN feature off, I was able to leave the above command running at least for 5 minutes without any problems.
I am currently running 378.56_2 F/W version on RT-N66U. Dual WAN mode is "Fallback". I was not able to reproduce it with Dual WAN mode "Balance".
Wow. Sorry I missed your topic. I tried searching but nothing came up. Probably my crooked fingers.
No, both ISPs are from Lithuania which provide WAN IP address and DNS server configuration via DHCP.
Actually I think you posted first so my bad on not seeing it :)
What I am doing for a workaround is unchecking "Connect to DNS Server automatically" and specifying Google's DNS 8.8.8.8 and 8.8.4.4 for both WAN connections. This is a workaround to the problem. I gotta think it's a pretty easy fix to not include the standby WAN's DNS servers in the dnsmasq config however.
I also did find this on line 2170 of /release/src/router/rc/wan.c (update_resolvconf)
/* TODO: Skip unused wans
if (wan disabled or inactive and it's not ppp with active man)
continue */
Which means ASUS hasn't gotten around to it yet ?
Unfortunately I can not use the workaround you mentioned, because then I loose the functionality where local hostnames are resolved to IPs in the LAN.
No you will not loose that functionality. What I mentioned just changes the DNS servers DNSMasq fowards queries to, will have no affect on LAN
Dual WAN is fun. Think of it as a multiple connection problem, and you get the chance to manage uplink/downlink together with two WANs. A total of 4 combinations. All under your control...configurable using iptables and iproute2 in a linux router.
In ASUSWRT, maybe all other consumer routers too, not only DNS won't respond occasionally, in general you'll get disrupted browsing experience on a constant basis if you opt for load balance mode. Most applications will be upset and not run too.
The other fail-over mode is a waste of bandwidth (being not used for most of the time). Since it's just like a single WAN, more compatible with most applications. So it's a suggested use of dual WAN by vendors. Quite frankly...both are not useful as-is.
