I have a problem with Dual WAN on my RT-AX58U.
I've read about little chances on having some support related to Dual WAN, but the problem here is that the same configuration is working on stock firmware.
My primary WAN is a simple DHCP from ISP. As a secondary WAN, I use an ethernet cable connected to 4G router using LAN1 port.
Everything woks fine when both primary and secondary ISP's are alive. But when primary ISP is ok, and secondary goes down - my internet drops.
After some testing I found out that the problem is with DNS requests - they always go through secondary WAN. So if secondary WAN goes down, DNS stops working, even when primary WAN works well for direct ICMP echoes.
I think this is also related to the fact that I have DNS over TLS configured.
Again, the same case works well on stock. Is it possible to have some advice on that?
Thanks a lot in advance!
