I just looked at the System Logs for my RT-AC66U, which is running in "Repeater" mode. It is using Merlin 374.41. The repeater is set to use the 5ghz radio only to connect to another RT-AC66U that is running as a wired/wireless router. The router is running Merlin 374.38.
The System Log in the Repeater shows the same message being reported about every 7 minutes or so (sometimes more frequently). I don't believe that whatever is being reported is affecting performance of either the router or the repeater adversely in any way, but I can't really be sure.
I will also check the System Logs in the Router as well and report back (by editing this if necessary).
I'm not going to post the entire list of messages from the Repeater's logs, but just a short snippet. They have continued as set out below up to the present time.
Can anyone explain what these messages mean? Are they benign (since they don't seem to be affecting performance), or are they reporting something that is actually symptomatic and that needs to be changed by adjusting some settings?
Any help appreciated.
RT AC66U "Repeater" System Log excerpt:
Nov 27 10:58:07 nmbd[21237]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name RT-AC66U<00> is one of our names !
Nov 27 10:58:40 nmbd[21237]: [2014/11/27 10:58:40, 0] nmbd/nmbd_become_dmb.c:become_domain_master_query_success(232)
Nov 27 10:58:40 nmbd[21237]: There is already a domain master browser at IP 192.168.1.1 for workgroup WORKGROUP registered on subnet UNICAST_SUBNET.
Nov 27 11:03:41 nmbd[21237]: [2014/11/27 11:03:41, 0] nmbd/nmbd_become_dmb.c:become_domain_master_query_success(232)
Nov 27 11:03:41 nmbd[21237]: There is already a domain master browser at IP 192.168.1.1 for workgroup WORKGROUP registered on subnet UNICAST_SUBNET.
Nov 27 11:08:42 nmbd[21237]: [2014/11/27 11:08:42, 0] nmbd/nmbd_become_dmb.c:become_domain_master_query_success(232)
Nov 27 11:08:42 nmbd[21237]: There is already a domain master browser at IP 192.168.1.1 for workgroup WORKGROUP registered on subnet UNICAST_SUBNET.
Nov 27 11:10:12 nmbd[21237]: [2014/11/27 11:10:12, 0] nmbd/nmbd_packets.crocess_browse_packet(1067)
Nov 27 11:10:12 nmbd[21237]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name RT-AC66U<00> is one of our names !
Nov 27 11:13:51 nmbd[21237]: [2014/11/27 11:13:51, 0] nmbd/nmbd_become_dmb.c:become_domain_master_query_success(232)
Nov 27 11:13:51 nmbd[21237]: There is already a domain master browser at IP 192.168.1.1 for workgroup WORKGROUP registered on subnet UNICAST_SUBNET.
Nov 27 11:18:52 nmbd[21237]: [2014/11/27 11:18:52, 0] nmbd/nmbd_become_dmb.c:become_domain_master_query_success(232)
Nov 27 11:18:52 nmbd[21237]: There is already a domain master browser at IP 192.168.1.1 for workgroup WORKGROUP registered on subnet UNICAST_SUBNET.
Nov 27 11:22:11 nmbd[21237]: [2014/11/27 11:22:11, 0] nmbd/nmbd_packets.crocess_browse_packet(1067)
Nov 27 11:22:11 nmbd[21237]: process_browse_packet: Discarding datagram from IP 192.168.1.1. Source name RT-AC66U<00> is one of our names !
And on, and on, and so forth, and so on.......
Edited to Add:
In the Router System Logs, there also appear to be some corresponding messages in the Router's Logs that seem to match what the Repeater is showing. I won't repeat them all, but sometime between when the Repeater shows "There is already a domain master browser...." the Router Logs show this (again, I'm just showing one instance...there are many and different intervals that seem to be between the Repeater events):
Nov 27 11:16:58 nmbd[345]: [2014/11/27 11:16:58, 0] nmbd/nmbd_packets.crocess_browse_packet(1067)
Nov 27 11:16:58 nmbd[345]: process_browse_packet: Discarding datagram from IP 192.168.1.42. Source name RT-AC66U<00> is one of our names !
Again, the question is, any reason for concern? Or is this totally benign?
I realize that because I'm using two AC66U's, they both have the same name, but I do not see any way in either unit to change that. And as for one of them needing to assume the role of "master browser" I understand that as well.
Is this therefore just something that occurs when using a router (as a router) and the same model as a repeater?
Thanks to anyone who can help me understand this.
ONE MORE ADD:
In case it wasn't clear, the Router's internal IP is 192.168.1 and the Repeater is assigned 192.168.42 by the Router.
And all of the Windows-based computers connected to either the Router or the Repeater are part of the same workgroup entitled "Workgroup" (there at least 8, sometimes more, at any given time on the network).
Edited to Add:
ONE MORE ADD:
