I live in a rural area with only a wireless Internet provider. My neighbor has a view of the antenna so we share the service. I wanted to keep my business network private, so I thought I would put a wireless router in my place and use a wireless bridge between my router and his with his having the actual Internet connection.
So he has an older Linksys WRT54G connected to the internet on its WAN port. I have a Netgear WNR2000 [2.4MHz 300MPS N] with a printer, storage device and DVD player on the LAN ports. I bought a Netgear WCE2000 for a bridge.
Here's the oddness:
1) If I wirelessly connect my laptop [Intel Ultimate N6300] to his WRT54G, I get the full rated speed of the connection.
2) If I plug my Netgear WNR2000 into the Internet connection and wirelessly connect, all good.
3) If I connect the WRT54G to the Internet, run a wired connection from the WNR2000 WAN port to one of the WRT54G LAN ports and wirelessly connect to the WNR2000, all is good.
4) If I use the WCE2000 as a client on my laptop and wirelessly connect to either router, speeds are fine.
When I then connect the WCE2000 wirelessly to the WRT54G[Internet connected] and plug it into the WAN port of the WNR2000, the download speeds are <10% of any other configuration. Upload speeds are fine. This testing done using speedtest.net.
In other words each piece works perfectly by itself, but the combo doesn't. And only the download side is a problem.
I used a very similar setup at another location for two years with no issues. The difference was that there both routers were Linksys WRT54Gs and the bridge was made by Engenius. With that setup, I used 192.168.1.x for the DHCP servers on both routers, just restricted them to different ranges. With the Netgear WNR2000, it refuses to use the same public address group as the Internet connected WRT54G and instead demands that its clients be 10.0.0.x.
I'd appreciate any thoughts or suggestions.
TIA.
Here's the oddness:
TIA.
