Offline via WLAN... But online via LAN ??!
Kamikaze01
As the title say, my problem seem to be WLAN :(
Since 2 hours I am offline via WLAN, but online via LAN.
What can this cause?
I restart the modem and then restart my AC68U - but still all WLAN Clients are offline :(
Ther is no Guest WIFI active...
Any help?
Looks normal I think... :-(
Still offline via 2.4 WLAN.
Just tried and get online via 5 GHz... :-o
Hmm...
Okay I just tried 5 Ghz with the phones and still offline ... But my Shield_TV is online via 5 Ghz...
So it seem to be a problem with the Mobile phones... Or some DHCP Problem...
But it worked like a Charme the last month... And since a few hours only the mobile phones are offline :(
What do you mean by "offline"? Everything looks like it's connected to the router OK.
Are you talking about connectivity to your LAN or to the internet? If it's the internet, are you going through a VPN?
Facepalm...
Thank u so much @ColinTaylor .
You are right - it was a VPN problem.
My Shield_TV is routed over WAN, so they are connected to the internet...
My Phones are routed over VPN.
And killswitch worked the way it should: makes them offline when not connected to VPN...
I am sorry that I did not checked this at first...
Thank u for your quick answer and the solution :))
Happy again !!!
