One device keeps getting disconnected from N66U repeater
Yipee Kaiyay
I have a Sony android phone that keeps disconnecting and reconnecting to my n66u repeater. Main router is ac68u.
When I connect directly to the main router everything works fine.
All other devices connect without issues to the extender.
Both routers are running the latest Asus firmwares.
I don't have other issues with the internet or anything...it's just this one device that keeps disconnecting as soon as I connect to the extender.
I did install ddwrt on the n66u temporarily just for giggles. My phone connected just fine...but ddwrt has it's own annoying issues that pop up randomly.
I have installed john's fork ,also...same issue with disconnects.
I'm out of ideas.
I'm out of ideas.
"In Repeater mode, the DHCP-assigned IP address changes. Install and use the Device Discovery Utility to get the wireless router's new IP address."
Quote from the Administration web page for the 66...is this a factor?
If both routers share the same IP, you will have a conflict, especially if you use DHCP on the phone...the phone then has its pick and will go back and forth depending on signal strength. Set up a unique static IP on the phone, not shared with both routers. On the other hand, YMMV...talking thru my hat here because I have never used a repeater, just use the 66 as my main gateway.
