OpenVPN Client / Notification when loosing public IP
Emanuel Paul
Hello
I have the problem, that a OpenVPN client on my RT-AC86U (Merlin 382.1_2) looses the public IP from time to time.
It would be a very good feature, to receive an email if this happens. Is there a possibility to set this up? Script?
Thanks in advance.
Script?
Something like this?
#!/bin/sh
VER="v1.01b"
# Check Public WAN IP of the VPN Client
#     ChkVPNIP     { 'vpn_client_id' }  [ curl ]
#     ChkVPNIP     1
#                  Check status of VPN Client 1 using 'STUN' method
#     ChkVPNIP     1 curl
#                  Check status of VPN Client 1 using 'curl' method
SendMail(){
    # Use e-mail method of your choice......
             #=====>>>     insert code here   <<<=====#
    return 0
#=====================================Main==============================
VPN_ID=$1
VPN_WANIP=
echo -e
logger -st "($(basename $0))" $$ $VER "VPN Public WAN IP checker....."
echo -e
if [ ! -z "$1" ];then
    if  [ "$(nvram get "vpn_client"$VPN_ID"_state")" == "2" ];then
        if [ "$2" != "curl" ];then
            if [ -f /usr/sbin/gettunnelip.sh ];then
                sh /usr/sbin/gettunnelip.sh ${VPN_ID}
                VPN_WANIP="$(nvram get vpn_client${VPN_ID}_rip)"
            fi
        fi
        if [ -z "$VPN_WANIP" ];then
            VPN_WANIP=$(curl --connect-timeout 5 -s --interface "tun1"${VPN_ID} "http://ipecho.net/plain")
        fi
            logger -st "($(basename $0))" $$ "VPN Client" $VPN_ID "lost it's public WAN IP address"
            SendMail
        else
           logger -st "($(basename $0))" $$ "VPN Client" $VPN_ID "public WAN IP is"  $VPN_WANIP
        fi
    else
        echo -e "\a"
        logger -st "($(basename $0))" $$ "***ERROR*** VPN Client" $VPN_ID "isn't connected!"
    fi
else
    echo -e "\a"
    logger -st "($(basename $0))" $$ "***ERROR*** Missing arg1 vpn_id e.g. 1,2,3,4 or 5"
fi
echo -e
exit 0
Thank you. Looks like what I was searching for. To be honest, I don't have a clue about things like this:-). Is there anywhere a tutorial for the needed e-mail code? And where do I have to add the whole code?
Thank you. Looks like what I was searching for. To be honest, I don't have a clue about things like this:). Is there anywhere a tutorial for the needed e-mail code? And where do I have to add the whole code?
There are examples here
RMerlin Wiki
Thanks. Found this
#!/bin/sh
FROM="your-gmail-address"
AUTH="your-gmail-username"
PASS="your-gmail-password"
FROMNAME="Your Router"
TO="your-email-address"
ntpclient -h pool.ntp.org -s &> /dev/null
sleep 5
echo "Subject: WAN state notification" >/tmp/mail.txt
echo "From: "\"$FROMNAME\"" \"<$FROM>\"" >>/tmp/mail.txt
echo "Date: `date -R`" >>/tmp/mail.txt
echo "" >>/tmp/mail.txt
echo "I just got connected to the internet." >>/tmp/mail.txt
echo "My WAN IP is: `nvram get wan0_ipaddr`" >>/tmp/mail.txt
echo "Uptime is: `uptime | cut -d ',' -f1 | sed 's/^.\{12\}//g'`" >>/tmp/mail.txt
echo "---- " >>/tmp/mail.txt
echo "Your friendly router." >>/tmp/mail.txt
cat /tmp/mail.txt | sendmail -H"exec openssl s_client -quiet \
-CAfile /jffs/configs/Equifax_Secure_Certificate_Authority.pem \
-connect smtp.gmail.com:587 -tls1 -starttls smtp" \
-f"$FROM" \
-au"$AUTH" -ap"$PASS" $TO
rm /tmp/mail.txt
But only found code to send mail after router is booting. Is it the same for my use?
Thanks. Found this
#!/bin/sh
sleep 5
-f"$FROM" \
rm /tmp/mail.txt
Yes. ....assuming you have a Google Gmail account.
You will probably need to alter the Subject line, and also modify the body of the email, then simply copy 'n'paste it into the script where indicated, but don't copy these three lines:
#!/bin/sh
sleep 5
Did the changes. Saved the file with Notepad++ as linus script (.sh). Copied it to /jffs/scripts on the router. Then activated it with "chmod a+rx /jffs/scripts/*", activated "Enable JFFS custom scripts and configs" in the router and rebooted the router.
Is there a way to test if it works?
Indeed assuming your script is called 'ChkVPNIP.sh' and you are testing VPN Client 3
cd /jffs/scripts
./ChkVPNIP.sh   3
P.S. You could also temporarily add a line to call the SendMail routine when it retrieves the public IP just to test that the email works!
Hello
Have you edited your last post? Because in the email I recieved it was the following:
Indeed
cd /jffs/scripts
./ChkVPNConfig.sh
Hopefully the screen shows a report, and you can now also check the logging messages in Syslog
e.g. to see if the script has actually executed
grep -i chkvpnconfig.sh /tmp/syslog.log
So now you need to schedule the script to run at regular intervals
e.g. every hour
cru l
cru a Track_VPN_Config "0 */1 * * * /jffs/scripts/ChkVPNConfig.sh
cru l
So should be able to issue the Syslog scanning debugging commands to quickly make a visual comparison to see if the lines reported change
So for detailed debugging, issue
grep -i summary: /tmp/syslog.log
grep -i vpnroutes: /tmp/syslog.log
But anyway. My file is called ChkVPNConfig.sh but after "cd /jffs/scripts" "./ChkVPNConfig.sh" gives me a "not found". Also "./ChkVPNConfig.sh 2" gives me a "not found". I use VPN Client 2.
If I do "ls" the file is listed...
Indeed
cd /jffs/scripts
./ChkVPNConfig.sh
Weird the post you have quoted was a reply I created for a different thread :eek::eek:o_Oo_O
Your script should be called ChkVPNIP.sh
You have probably used a non Unix file editor to create the script
Try converting the script to Unix format
dos2unix   /jffs/scripts/ChkVPNIP.sh
That's strange...
Intresting. I created the script with Notepad++ and saved it as "Unix script file", but only after the dos2unix it works...If I execute it, it shows my the public IP of VPN Client 2.
Now hopefully the last question:
How does the line look like I can temporarily add to send mail when the public IP is found? And where do I have to add it in the script?
That's strange...
Change
   SendMail
else
fi
to
   SendMail
else
   SendMail        # <<===== Temporarily add this line =====
fi
Once you have proved the script monitoring/email works, you will need to schedule the script using cru/cron
e.g. every hour
cru a CheckVPNIP "0 * * * * /jffs/scripts/ChkVPNIP.sh"
or change the frequency to whatever interval that meets your requirements.
The email seems to work. Thank you very much.
Tried to get information about the needed cron job. Found one that says, that the cron job needs to be placed at "/var/spool/cron/crontabs/" , the other says that it has to be added into the user script. Which is true for me?
About the frequency I found informations that there have to be six fields. Is there a difference to your code, which only contains five fields?
If I use six fields I think it should be like this to check every half hour:
cru a CheckVPNIP "30 * * * * * /jffs/scripts/ChkVPNIP.sh"
Hmm, strange....:rolleyes:
What do the FIVE Cron fields mean?
Very easy Cron command generator
Ok. In this case it will be:
#!/bin/sh
cru a CheckVPNIP "30 * *  * * /jffs/scripts/ChkVPNIP.sh"
And it should be placed under "/var/spool/cron/crontabs/", right? Is there any restriction to the filename, except saving it as unix script file? I would name it cronjobs.sh
#!/bin/sh
The router firmware uses the 'cru' command to make it easier for novices to manage crontab.
Having manually issued the above command issue the list command
cru   l
30 * * * * /jffs/scripts/ChkVPNIP.sh #CheckVPNIP#
The schedule identifier tag is shown between the '#' characters and is used to delete the scheduled task
e.g.
cru   d    CheckVPNIP
'cronjobs.sh' is fine but you will need to call it from init-start if you want it to run after every boot.
see Wiki/documentation for Asuswrt-merlin
Ok. So the file is the following?
#!/bin/sh
cru   l
What do you mean with "delete the scheduled task"? The scheduled task is the code, not?
And what for it this then?
cru   d    CheckVPNIP
Sorry, but it seems that I'm even not a novice:-)
#!/bin/sh
cru   l
cru   d    CheckVPNIP
Sorry, but it seems that I'm even not a novice:)
:rolleyes: Suppose you decide to change your mind and decide that every 30mins isn't appropriate, you would need to delete the current schedule and resubmit a modified 'cru a' command with your new schedule.
Thanks for the link again. I checked the Wiki but for a novice it's hard to find the needed information. If you don't know, what you are looking for...And under cronjobs is not much information useful for me, as I found out.
Ok. Please let's first do the code for the file, which I place at "/jffs/scripts/init-start". Is it this or not?
#!/bin/sh
Just for my understanding because I don't think that I need the manual codes when I have set up a cron script...
This code does the same, entered in command line, but only until the next reboot. Right?
cru   l
And this code entered in command line does stop the manually code from working before a reboot, Right?
cru   d    CheckVPNIP
But if there is a script and I decide to change the time, I have to change the script and after the next reboot the changes are active, right?
Hello again.
I tested the scripts the last days. Something does not work.
in /jffs/scripts/ I have the following script (with correct and tested email credentials):
#!/bin/sh
VER="v1.01b"
#     ChkVPNIP     1
#     ChkVPNIP     1 curl
SendMail(){
             FROM="xxxxxxxx"
             AUTH="xxxxxxxx"
             PASS="xxxxxxxx"
             FROMNAME="RT-AC86U"
             TO="xxxxxxxx"
             echo "Subject: Public IP notification" >/tmp/mail.txt
             echo "I just lost my public IP on OpenVPN." >>/tmp/mail.txt
             -f"$FROM" \
             rm /tmp/mail.txt
    return 0
VPN_ID=$1
VPN_WANIP=
echo -e
echo -e
            fi
        fi
        fi
            SendMail
        else
        fi
    else
        echo -e "\a"
    fi
else
    echo -e "\a"
fi
echo -e
exit 0
SendMail when publicIP is found is active, just to test, if its working. The script itself works and sends email when I manually start it with ./ChkVPNIP.sh 2.
under /jffs/scripts/init-start/ I have the following:
#!/bin/sh
cru a CheckVPNIP "15 * * * * /jffs/scripts/ChkVPNIP.sh"
But it seems that this does not start the ChkVPNIP.sh script...
What did I wrong?
