OpenVPN killswitch `prohibit` rule not applied via VPN Director / CLI (FW 3004.388.11)
XxUnkn0wnxX
Hi all,
I’ve been testing the OpenVPN client “Kill Switch” behavior on Asuswrt-Merlin and I’m seeing inconsistent behavior depending on how the tunnel is started.
Tested on:
  • Router: ASUS GT-AX11000
  • Firmware: 3004.388.11
  • Branch: ubi firmware (NOT ROG build)
  • OpenVPN only
  • Tested with Policy Rules / VPN Director only
  • IPv6 globally disabled on the router
The specific thing I’m tracking is the per-client RPDB rule:
from <ROUTED_CLIENT_LAN_IP> prohibit
Case 1 (works):
When Kill Switch is enabled and the tunnel is started from:
<ROUTER_WEBUI_BASE_URL>/Advanced_OpenVPNClient_Content.asp
…the prohibit rule is installed as expected:
admin@router:/# ip rule | grep <ROUTED_CLIENT_LAN_IP>
10210:  from <ROUTED_CLIENT_LAN_IP> lookup ovpnc1
12211:  from <ROUTED_CLIENT_LAN_IP> prohibit
Case 2 (problem):
If the tunnel is started via:
  • VPN Director UI:
    <ROUTER_WEBUI_BASE_URL>/Advanced_VPNDirector.asp
  • OR CLI:
admin@router:/# service start_vpnclient1
…then the tunnel can come up / routing can occur, but the kill switch prohibit rule does NOT get applied (i.e. no
line).
Verification command:
Expected (Kill Switch respected regardless of start method):
Observed (when started outside OpenVPN Client page):
(no prohibit rule)
Question:
  • Is this intended behavior, or a bug/regression?
  • If intended: could the kill switch logic be applied consistently regardless of the start path (OpenVPN Client page vs VPN Director toggle vs service start/stop), so routed clients never silently fall back to WAN when Kill Switch is enabled?
Cheers
CLI: that's normal, you are only starting the client, you also need to restart/reapply routing:
service start_vpnroutingUNIT
Where UNIT is the instance number between 1-5.
VPNDirector page: I'll take a look, it's possible it's missing the vpnrouting call.
Hi all,
is there something similar with Wireguard clients ?
Thx,
GS
Hi all,
Thx,
GS
Same function (vpnrouting), but the unit must be "0" - it will be reapplied for all instances then.
