OpenVPN config file problem in .35_2
  • Thread starter Thread starter Deleted member 22630
  • Start date Start date
D
Guest
Hi RMerlin,
In the OpenVPN server settings, I enabled "Extra HMAC authorization (tls-auth)" for Incoming (0). The generated config file then contains the line:
</tls-auth> 1
which cannot be parsed when importing into Android clients.
This should be:
</tls-auth>
key-direction 1
which is parsed and works properly.
Regards,
Scott.
Another problem with OpenVPN server config is that when using username/password authentication, a password with several "." (period) characters is neither displayed, nor works.
Don't use three dots in a row - this is used to determine if a field is truncated or not.
The same issue would happen in a lot of other places on the webui BTW. This is something that will also happen with the original FW.
Hi RMerlin,
</tls-auth> 1
This should be:
</tls-auth>
key-direction 1
Regards,
Scott.
I'll have to take a look. The config generation code was developed by Asus, so there might be some issues still left with it as it's fairly new.
Hi RMerlin,
</tls-auth> 1
This should be:
</tls-auth>
key-direction 1
Regards,
Scott.
Thanks - should be fixed now.
I would think so too, seems that the details pages also does not show somehow for my old config, doing a factory reset then comes out fine.
