OpenVPN Bandwidth tweaking
Tamo
Hi all,
we are searching some tips or advices about vpn speed.
we try to connect 2 networks with OpenVPN in site to site connection. 1 router is a RT-AX88U (3004.388.4), the other one is an OpnSense router.
Both sites have 1Gb/s fiber connection but the bandwidth throught VPN is limited to ~40Mb/s.
We have tried hard to have successful connection but we need a better speed.
We tried a speed test with iperf. 440Mb/s with direct connection via Internet with a port forwarding. 40Mb/s throught OpenVPN.
The configuration is as follow :
Tun
UDP
Auth Mode with Static Key
KEys and certificates generated by AsusMerlin router.
HMAC : Auth SHA 256
Cipher : AES-128-CBC
Compression : LZO
Custom conf :
sndbuf 0 (also pushed)
rcvbuf 0 (also pushed)
Is someone as tips to have a better speed.
Regards
Tamo
Also use AES-128-GCM - saves a bit of overhead as it won`t require a separate SHA hash.
Custom conf :
Maybe you can try:
fast-io
data-ciphers AES-128-GCM:CHACHA20-POLY1305
data-ciphers-fallback AES-128-GCM
thanks we will try it.
GCM seems to be not supported. VPN server won't start and system logs says that
Dec 4 18:02:00 ovpn-server2[4086]: Cipher 'AES-128-GCM' mode not supported
Dec 4 18:02:00 ovpn-server2[4086]: Exiting due to fatal error
Perhaps we can add it by side.
Asus GT-AXE16000
my speed is only 200Mbit/sec.
If I read correctly, it should know 250 Mbit/sec.
Did I set everything up correctly?
Data ciphers: AES-128-GCM:AES-256-GCM:AES-256-CBC:AES-128-CBC:CHACHA20-POLY1305
THX :)
Not every server will be able to hit the theorical limit. If you get 200+, then you are within the expected range.
Yes, 'up to'.
