OpenVPN configuration help
yelo3
Hello, I need help on configuring OpenVPN.
I have currently configured it using default settings, and it works well with my Android phone.
Now I have bought an air conditioning system by Daikin, which can be controlled using WiFi.
The android app does a broadcast lookup when it starts, to find all daikin uints:
255.255.255.255:30050 UDP
DAIKIN_UDP/common/basic_info
The app works well in my internal network, but it can't find anything when connected through VPN.
Any suggestion?
Any suggestion?
I'm facing the same problem using L2TP/IPSec. Have you solved it?
Regards
Pavel
