OpenVPN error/warning "write UDPv4: No buffer space available"
joegreat
Dear All!
I am using a permanent OpenVPN connection via Proton VPN and linked to a guest WLAN for streaming from a neighbor country.
From time to time, I get the warning/error "write UDPv4 []: No buffer space available (fd=8,code=105)" in syslog - but I cannot relate the error with streaming issues - streaming works fine a far as I can see.
Any suggestions to fix this error or should I simply ignore it?
My research could not find a fix for it - what have I tried so far:
- searched the Internet for hints - found Linux parameters (/proc/sys/net settings) and MTU suggestion
- I fiddled around with OpenVPN parameters, but could not find out how the options tun_mtu, link_mtu, mss_fix and max_frament and fragment relate to each other
- mtu-test gave some results (see below), but I could not deploy them
Setup:
- Main router RT-AX88U Pro with Merlin v3006.102.6 & Entware 64-bit, OpenVPN, Samba and some Scripts
- 1 Gbit/250 Mbit FTH with 2.5 Gbit WAN connection to 1 and 2.5 Gbit LAN setup
- multiple guest WLANs (one for streaming over VPN)
- OpenVPN speed: 311.99 down, 234.19 up, ping 17 ms, jitter 0.3 ms (internet speed test under Adaptive QoS)
Below some snippets from Syslog:
Jan  4 20:03:12 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  5 02:03:34 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  5 18:03:08 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  5 19:24:38 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  6 06:03:17 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  6 06:03:22 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  6 06:03:26 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  6 08:03:09 ovpn-client1[10409]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  6 23:36:37 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  7 16:03:19 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  7 18:18:27 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  8 22:03:09 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  9 18:03:12 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan 10 05:00:07 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan 10 22:03:10 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan 11 08:03:27 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan 11 09:36:17 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan 11 12:03:32 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan 11 14:03:11 ovpn-client1[1345]: write UDPv4 []: No buffer space available (fd=8,code=105)
Jan  6 14:28:12 ovpn-client1[6947]: WARNING: using --fragment and --mtu-test together may produce an inaccurate MTU test result
Jan  6 14:28:12 ovpn-client1[6947]: WARNING: if you use --mssfix and --fragment, you should use the "mtu" flag for both or none of of them.
Jan  6 14:11:40 ovpn-client1[25226]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1556,1556] remote->local=[1552,1552]
Jan  6 14:17:01 ovpn-client1[30083]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1580,1580] remote->local=[1576,1576]
Jan  6 14:23:20 ovpn-client1[2858]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1580,1580] remote->local=[1576,1576]
Jan  6 14:35:20 ovpn-client1[15633]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1524,1524] remote->local=[1520,1520]
Jan  6 14:46:04 ovpn-client1[20732]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1524,1524] remote->local=[1520,1520]
Jan  6 14:50:23 ovpn-client1[23611]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1524,1524] remote->local=[1520,1520]
Jan  6 14:56:03 ovpn-client1[27057]: NOTE: Empirical MTU test completed [Tried,Actual] local->remote=[1524,1524] remote->local=[1520,1520]
Jan  6 14:42:55 ovpn-client1[20732]: Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
Jan  6 14:42:55 ovpn-client1[20732]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1423 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan  6 14:42:57 ovpn-client1[20732]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan  6 14:47:16 ovpn-client1[23611]: Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
Jan  6 14:47:16 ovpn-client1[23611]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1423 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan  6 14:47:18 ovpn-client1[23611]: Data Channel MTU parms [ mss_fix:1408 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan  6 14:52:55 ovpn-client1[27057]: Control Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1250 tun_max_mtu:0 headroom:126 payload:1600 tailroom:126 ET:0 ]
Jan  6 14:52:55 ovpn-client1[27057]: Data Channel MTU parms [ mss_fix:0 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
Jan  6 14:52:57 ovpn-client1[27057]: Data Channel MTU parms [ mss_fix:1400 max_frag:0 tun_mtu:1500 tun_max_mtu:1600 headroom:136 payload:1768 tailroom:562 ET:0 ]
OpenVPN manual is available:
Explains --fragment --mtu-test --mssfix etc ... See below
NETWORK CONFIGURATION​
Full Manual:
