OpenVPN, no password?
Henric Rosvall
Hi !
I connect to work through OpenVPN, and now that I have a new router I thought that the router could do the connection instead of OpenVPN GUI.
But it has proven difficult to get the connection working.
Every time I connect with OPenVPN GUI I need to input a password (to be able to decrypt the certificates?). And then it works like it should.
But in the router config there doesn't seem to be an option to input a password to unlock the encryption and connect. So the connection fails with the message:
Feb 20 18:19:45 openvpn[6057]: Error: private key password verification failed
Feb 20 18:19:45 openvpn[6057]: Exiting due to fatal error
Any idea what is wrong and how I could fix it?
The current ovpn-config that works fine in OpenVPN GUI if I just input my password:
#OpenVPN Server conf
tls-client
client
dev tun
proto udp
tun-mtu 1500
remote [IP TO THE FIREWALL AT WORK] 1194
ca [inline]
<ca>
-----BEGIN CERTIFICATE-----
[THE CA CERTIFICATE]
-----END CERTIFICATE-----
</ca>
cert [inline]
<cert>
[THE USER CERTIFICATE]
</cert>
key [inline]
<key>
-----BEGIN ENCRYPTED PRIVATE KEY-----
[THE KEY CERTIFICATE]
-----END ENCRYPTED PRIVATE KEY-----
</key>
cipher BF-CBC
comp-lzo
verb 3
ns-cert-type server
Never mind. I managed to solve it myself (after hours and hours of tinkering, I was just one small step from succeeding).
A description of how to solve it will be posted shortly
Solution:
I needed to connect to OpenVPN with the router, as a road warrior.
The server was using IPCop with an OpenVPN plugin.
So I had a .p12 file and a .ovpn config file collected from IPCop.
But those files doesn't work very well with the Asus router. So there are a few steps to get it working.
First of all, we want to include all the certificates in the ovpn-file (to make things a bit easier)
I started out with this ovpn-file:
tls-client
client
dev tun
proto udp
tun-mtu 1500
remote [IP to the server] 1194
pkcs12 Henric.p12
cipher BF-CBC
comp-lzo
verb 3
ns-cert-type server
The router doesn't seem to like pkcs12-certificates. So we need to convert it into separate certificates.
So what I did, was to run this command in the command prompt:
openssl pkcs12 -in c:\Temp\Henric.p12 -out c:\Temp\Henric.pem
This converts the pkcs12-certificate into a file containing the separate certificates that we'll need.
IMPORTANT: You'll need to supply both an import password AND an export password when asked. If you don't supply it with an export password, it won't generate a user key, and you'll be pretty much f*cked.
Just write the same password for both.
Now we have a pem-file with three keys
  • one CA certificate for the server
  • one sertificate for your user
  • one key for your user.
But the user key have a password, and that's not something the Asus router can handle.
So we need to create a new user key based on the old one, without the password.
So we open the generated .pem-file.
It should contain three certificates (eache certificate starts with -----BEGIN CERTIFICATE----- and ends with -----END CERTIFICATE-----).
The hird (bottom) one is your user key.
Copy it (including the begin and end lines) and paste it into a new file, that we will name HenricKey.key in this example.
Then run the following command
openssl rsa -in c:\Temp\HenricKey.key -out c:\Temp\HenricKey_NoPass.key
Now we have all the data we need. All that is left is to modify the .ovpn-file.
Open the old .ovpn-file and delete the line that starts with pkcs12.
We now need to add the three certificates, one ca certificate, one user certificate, and the user key that has no password. In the end it will look like this:
tls-client
client
dev tun
proto udp
tun-mtu 1500
ca [inline]
<ca>
<A bunch of characters and numbers>
</ca>
cert [inline]
<cert>
</cert>
key [inline]
<key>
-----BEGIN RSA PRIVATE KEY-----
-----END RSA PRIVATE KEY-----
</key>
cipher BF-CBC
comp-lzo
verb 3
ns-cert-type server
The "ca" is the second certificate in Henric.pem, the "cert" is the first certificate in Henric.pem, and the "key" is the certificate found in HenricKey_NoPass.key
Just upload the .ovpn-file to the router, and everything should work out perfectly
[Many Bothans died to deliver this message]
(or at least many ours of trial and error :) )
