OpenVPN on RT-AX86U pro vs RT-AC68U, missing choices
xlarge
I use merlin on the old AC router and going to replace it with the AX-router and discover that there is very much limited choises in the VPN-setup (OpenVPN). Enclose pics og old and new router vpn.
1. Can asus ordinary fastware not give my both client1 and client2 (used today with some differences, mainly security) ?
2. May be same question, but howto setup (change) 10.8.0.0 to 10.16.0.0 (server2/client2)?
3. When I try to change VPN-klient max from 1 max 16 (wish 3), I get a popup with login as admin and a warning if I want to create more than one admins. That was not what I want - I just need to have more than 1 client1-user.
The pictures "Home router--" is from the new RT-AX86U Pro - router (moved later to the remote place). The old remote router is RT-AC68U with merlin software.
I have read that the ordinary asus fastware now should be as good as merlin, but if I can't use server2, I have a problem. Hope there is a solution.
Asuswrt only supports one server.
