OpenVPN ports 1025-65535
RSengine
My ASUS router's OpenVPN configuration page says "Due to security concerns, we suggest using a port from 1025 to 65535". I've been setting my port as 443 to mask my VPN packets as HTTPS traffic when travelling. I couldn't find anything about VPN security on Google with regard to ports 1025 to 65535. Am I sacrificing some security as a result of setting my port as 443?
Where are you seeing that message? I can't see it myself. What router model do you have?
On a normal Linux system ports <1024 are "system ports" that can only be bound to by root and therefore has security implications. That's rather academic on an Asus router IMHO as just about everything runs as root.
It seems that message appears when AiCloud 2.0's Web access port is set as 443 in http://router.asus.com/cloud_settings.asp (even if AiCloud 2.0 is disabled, like it is in my router). Changing that to something else made the message disappear.
Could a client connected via VPN somehow run commands as root on my router without knowing the admin login then?
No, although I'm not saying it's impossible because all software has the potential to contain bugs. But OpenVPN is very secure and reliable making that extremely unlikely.
