OpenVPN replay warning with NordVPN
Stardust
Well I get this log when using NordVPN on my AX86U - what can I do?
Jul 24 20:26:37 ovpn-client1[2974]: AEAD Decrypt error: bad packet ID (may be a replay): [ #732291 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
You might see this from an attempted MITM (Man in the Middle) attack. But it's NOT as if I haven't seen these on an occasion myself. I don't worry about it unless they become pervasive. After all, it might simply be a corrupted packet that's being misinterpreted as a replay attack. I'd need to see a LOT more of these to have concerns. If you do, I'd try switching to TCP (I assume you're using UDP) and see if it helps.
Thank you :)
My guess is now that it might a package problem like you write
