AEAD Decrypt error: bad packet ID
Jonnny
Using VPN Director to redirect a device (IP), through a VPN Client (OpenVPN), the following error appears using torrent traffic:
Jun 23 10:05:32 ovpn-client1[16663]: AEAD Decrypt error: bad packet ID (may be a replay): [ #10543379 ] -- see the man page entry for --no-replay and --replay-window for more info or silence this warning with --mute-replay-warnings
If using the Wireguard client, this error no longer appears.
I remember, in the past to configure the OpenVPN Server (not client), on the router, I had to set it to TCP protocol so that a similar error does not appear when viewing streaming channels.
In some research I did, it is mentioned that it could be the UDP/TCP protocol, MTU value, OpenVPN client configuration...
Has anyone experienced this error?
Thanks.
Thanks.
Honestly very little familiarity with OVPN but if you're using UDP, retransmissions are common and I'm wondering if that is what it means by "replay".
I believe the default OpenVPN config assumes you have 1500 MTU on the WAN, is that the case with your ISP? If not it could be fragmentation but that doesn't seem to line up with that log message.
If you have the option of using wireguard, why don't you use that? It is much lighter weight and more efficient.
I've tried changing the MTU value but to no effect.
The times I tried Wireguard Client/Server, I switched back to OpenVPN. A big drawback for me on the Wireguard Client, it only allows one session at same time unlike OpenVPN.
Thanks.
The AEAD error is not an error as such. It's just a message saying it's happening - a non-error. Also it's unrelated to MTU.
I run my own VPN on a vps and have found that adding
to the client's custom configuration, as the log is advising would mute the AEAD messages.
