OpenVPN Server 384.8_2 problem Android
snakebite3
Ever since I upgrade to 384.7 and now 384.8_2 the VPN Server doesn't work properly with Open VPN connect(3.0.5[1816]) on Android.
I have Client will use VPN to access "Lan only"or "Both" but I can't access the router from a external address.
This is my settings
RSA Encryption 2048
Advanced Settings:
Interface Type: TUN
Protocol: TCP
Server Port: Default
Authoriztion Mode: TLS
UN/PW Authentication: Yes
UN/PS Auth.Only: No
TLS control channel security: Encrypt Channel
HMAC Authentication: SHA 1
Advertise DNS to clients: Yes
Cipher Negotiation: Enable (with fallback)
Negotiable ciphers: AES-128-GCM:AES-256-GCM:AES-128-CBC:AES-256-CBC
Legacy/fallback cipher: AES-128-CBC
Compression: None
Is there something wrong with my Config? or Something wrong with the Client I'm using?
