sanderveeken
I'm using an AC88U and am running the latest available Merlin firmware. Since a few months, I've been using the built in OpenVPN server to securely access my home server when away from home.
The connection itself works great, was easy enough to set up and configure and is very stable and fast. My problem is that whenever the router reboots, the OpenVPN server fails to restart and this is because the word "up" somehow gets added to the "custom configuration" field at the bottom. Even if I log in to the router and try to start OpenVPN server manually, it will fail ("daemon failed to start") until I clear the "custom configuration" field and hit apply. Then it starts and runs fine again.
This wouldn't even be a huge issue except that I have the router reboot weekly (Sunday night) just to clear up stuff. When I didn't, it would sometimes (infrequently) hang or be very slow randomly and this was an easy and painless way to deal with that has no adverse effects - until now.
I'd like to know why the field keeps being refilled after a reboot, and if there is a way to reliably restart OpenVPN server after a reboot.
